Tackling Titanium: Machining Tips and Techniques Guide
Titanium Varieties
Titanium Concerns
Workholding
Heat Generation
Heat is a formidable enemy, and heat generation must be considered when selecting speeds and feeds. While commercially pure grades of titanium are softer and gummier than most of its alloys, the addition of alloying elements typically raises the hardness of titanium. This increases concerns regarding generated heat and tool wear. Maintaining a larger chipload and avoiding unnecessary rubbing aids with tool performance in the harder titanium alloys, and will minimize the amount of work hardening produced. Choosing a lower RPM, paired with a larger chipload, can provide a significant reduction in temperature when compared to higher speed options. Due to its low conduction properties, keeping temperatures to a minimum will put less stress on the tool and reduce wear. Using high-pressure coolant is also an effective method to reduce heat generation when machining titanium.
Galling and Built-Up Edge
The next hurdle to consider is that titanium has a strong tendency to adhere to a cutting tool, creating built up edge. This is a tricky issue which can be reduced by using copious amounts of high pressure coolant aimed directly at the cutting surface. The goal is to remove chips as soon as possible to prevent chip re-cutting, and keep the flutes clean and clear of debris. Galling is a big concern in the commercially pure grades of titanium due to their “gummy” nature. This can be addressed using the strategies mentioned previously, such as continuing feed at all times of workpiece contact, and using plenty of high-pressure coolant.
Titanium Solutions
In addition, selecting a proper tool coating can help make your job a successful one. With the high heat being generated during titanium machining operations, having a coating that can adequately deal with the temperature is key to maintaining performance through an operation. The proper coating will also help to avoid galling and evacuate chips effectively. Coatings such as Harvey Tool’s Aluminum Titanium Nitride (AlTiN Nano) produce an oxide layer at high temperatures, and will increase lubricity of the tool.
Tooling Solutions
As titanium and its many alloys continue to grow in use across various industries, more machinists will be tasked with cutting this difficult material. However, heat management and appropriate chip evacuation, when paired with the correct coating, will enable a successful run and profitable tool life.
Good article ! Always good to learn more information to better success !
It’s interesting that you recommend a lower RPM with a rougher blade for better titanium cutting. It makes sense that you’d want to keep the heat low as to reduce any hardening effects. This is something to remember for my project because if we decide to use titanium, making sure it’s safe and strong is important.
Good article ! Always good to learn more information to better success! It makes sense that you’d want to keep the heat low as to reduce any hardening effects.
According to HeatSign Titanium is as strong as steel but less dense, making it the perfect alloying agent with several metals like aluminum and iron.
Good article ! According to HeatSign Titanium is as strong as steel but less dense, making it the perfect alloying agent with several metals like aluminum and iron, plastic injection molding.
Would be nice if this article was more detailed with sample cuts and thus showing ideal machining rates for turning a 20mm bar in grade 5 or pure titanium vs a steel bar. That you use empirical information (at least using metric) while recommend what kind of tooling excels. This is your opportunity to showcase how your tooling is more effective than other carbide options with less desirable tool geometry.
