The power generation industry demands exceptional durability and precision, and Harvey Performance Company brands deliver exactly that. Our tooling solutions are designed to handle the extreme conditions of power plant manufacturing, from turbine components to energy infrastructure, ensuring the highest levels of performance and efficiency.
With a range of solid carbide end mills, drills, and custom solutions, our tools are built to withstand the challenges of high-heat, high-pressure environments while maintaining precise tolerances and extended tool life. Our coatings and tool designs are carefully selected to optimize performance and reduce downtime in power generation applications.
Harvey Performance Company brands are committed to empowering the power generation sector by providing tooling solutions that support both operational excellence and sustainability in energy production.
North America
Much like aerospace, power generation relies on complex turbine components made from challenging materials like titanium, Inconel, and stainless steel. Helical’s tooling is designed to thrive in these environments, with advanced geometries and coatings that deliver high material removal rates and long tool life—perfect for large-scale turbine blade and casing production.
Smaller turbines and intricate energy components require tooling that can reach where standard cutters can’t. Harvey Tool excels here, offering miniature and tapered solutions like 2-flute tapered ball nose end mills—ideal for tight, complex geometries found in smaller blades and compact assemblies.
Offline deburring remains a key step in power generation manufacturing—and ATA SGSPRO is built for it. With robust deburring and finishing tools, ATA helps improve part quality and reduce manual intervention in dedicated finishing cells, supporting cleaner edges, improved safety, and better long-term component performance.
Tool cribs in power generation facilities are stocked with proven performers—and Titan USA fits the bill. Offering a wide range of HSS and cobalt taps, drills, reamers, and end mills, Titan’s general-purpose tooling supports maintenance, repair, and operational needs throughout the plant floor.
Europe / Rest of World
ITC offers a solid range of tools designed for power generation applications, specializing in titanium and stainless steel machining. Their high-performance tools feature proven coatings that significantly extend tool life, ensuring efficient and durable results in demanding power generation environments. ITC’s solutions provide precision and reliability, making them ideal for applications that require superior cutting performance and extended tool longevity in tough materials.
Karnasch provides comprehensive machining support for the power generation industry, offering tools that cover everything from grinding to finishing. Their solutions are designed to meet the high demands of power generation components, ensuring precision, efficiency, and long-term performance. Whether for turbine components, valves, or other critical parts, Karnasch’s tools deliver high-quality results across a wide range of materials used in power generation manufacturing and maintenance.
Garryson offers a wide range of burs and routers specifically designed to address the unique needs of the power generation industry. Their tools excel in applications such as new blade deburring, chamfering, weld removal, and turbine refurbishment, ensuring precise finishes and superior performance. With a focus on durability and efficiency, Garryson’s tools provide reliable solutions for power generation manufacturers and service providers working in demanding environments.
