Understanding the Distinctions
Harvey Tool Product Offering
Choosing the Right Tool
Great article about engraving Cutters and Marking Cutters
Yes indeed, I learned alot about engraving blades here.
Looking for customised solutions for engraving cutter.
Hi Shrutesh,
Thanks for reaching out. Please contact Harvey Tool’s technical support team at 800-645-5609 and someone would be happy to help you!
Hello there! Excellent take on engravers and marking cutters. I particularly liked the bit about the tools having unique geometry features particularly the part where you expounded on shear flutes that offer better cutting action and the ability to evacuate chips easier as compared to a half-round engraver. I’ll be getting an engraved stale sign from this maker soon” https://www.countyhousesigns.co.uk, and I want to understand everything about its manufacturing and ensure to get the best one.
Great tips,laser marking discolors the surface of the material, while laser etching and engraving actually removes a portion of the surface area as it marks.
Thanks for explaining that choosing the correct tool is based on preference applicability. My brother needs to have some custom signs engraved for his small business. I’ll share this article with my brother as he determines the best way to create the engraved signs.
Thanks for pointing out that engraving materials are often used for softer materials such as wood and aluminum. I just needed to know the process I might need for the wood souvenirs that I plan to have for our wedding. We would have our dates and names imprinted there once we find a professional engraver we can trust.
Many thanks. keep up the good work
Great article, sorry I took so long to read it!! Is it possible to order directly from Harvey? The closest distributor is 2.5 hours away and doesn’t stock the parallel engraving cutters I need.
Thanks!
Hello George,
We currently do not sell direct. You can order the parallel engravers through a different distributor and have them drop ship the package to your location.
Well this is awesome post and written very well. Your point of view is very good.
Great Article well written thank you for providing this information keep writing
