September 15, 2025/0 Comments/in CNC Machining, Harvey Tool, Large Featured, Machining 101, Machining Techniques, Milling, Milling, Specialty Tools, Tool Coatings, Tool Geometry, Tool Selection, Troubleshooting Tips/by Harvey Performance Company
CNC engraving is a process that removes a small amount of material to create detailed images or shapes. Many manufacturers use this method for labeling parts or creating complex designs; however, not everyone is aware of the key techniques necessary for optimal results. When using an engraving tool, it is essential to consider several challenges that could affect both the tool and the operation.
Advantages of CNC Engraving
Compared to other engraving methods, CNC engraving is fast, consistent, and cost-effective. Thanks to their repeatability, CNC machines deliver consistent results when paired with a high-quality engraving tool. We suggest running the tool at a minimum of 6,000 RPM.
If your machine supports it, increasing the RPM can lead to even greater results. Running at lower speeds can negatively impact tool life. Choosing the right engraving tool requires considering production volume and tool engagement time. Key factors such as tip design, angle, and coating play a crucial role in maximizing efficiency and durability.
Proper Engraver Tool Selection
Most machinists understand that a square-corner end mill does not last as long as a corner-radius or ball-end mill due to its fragile cutting edge.
The same principle applies to CNC engraving tools. An engraver that comes to a sharp point is more fragile than one with a tipped-off or radius tip. For long production runs, consider using a tip-off or rounded tip design, as these geometries distribute cutting forces more evenly across the cutting edge, improving tool longevity. A tip-flat design will last longer than a pointed tip but not as long as a radius tip. If high-detail work is required, a pointed tip is preferable because it provides greater precision.
Pointed Tip Engraving Cutters
Tipped Off Engraving Cutters
Tip Radius Engraving Cutters
Environment and Detail Considerations
Similar to tip geometry, the engraving angle plays a critical role in visibility. The environment in which the engraving is used affects how well it can be seen. If the engraving is exposed to harsh conditions with elements like snow, mud, or dirt, debris can accumulate in the grooves, making it difficult to see and clean. A larger angle creates a wider groove, improving visibility and ease of cleaning.
The image below illustrates three different engraving angles offered by Harvey: the leftmost groove is 30° included, the middle groove is 60° included, and the rightmost groove is 120° included. Each of these engravings is only 0.009 inches deep.
Notice that the 120° engraving is more visible at a distance due to increased surface exposure. If a job requires precision and detail, a smaller angle is preferable. While geometry significantly impacts engraving visibility and tool longevity, another key factor in tool performance is the choice of coating.
Choosing a Tool Coating
A coated engraving tool will last longer than an uncoated one because the coating provides a protective barrier between the tool and the workpiece. Additionally, coatings help reduce heat absorption, increase lubricity, and decrease tool wear. Selecting the right coating depends on the material being machined.
For example, our AlTiN and AlTiN-Nano coatings perform best in stainless steel and nickel alloys. For non-ferrous materials such as aluminum or copper, our Amorphous Diamond coating is ideal. As an alternative to our Amorphous Diamond coating, we also offer ZrN or TiB2 coatings.
A common misconception is that diamond-coated tools can be used on ferrous materials. Instead, this leads to rapid heat generation and premature tool failure.
Successfully Running Your Engraver
Selecting the correct engraving tool is just as important as understanding how to operate it properly. Even the highest-quality tool will be wasted if not used correctly. As with any machining operation, you must consider depth of cut, work holding methods, and appropriate speeds and feeds
Cutting Speeds and Feeds for Engraving
The tip is the most delicate area of the tool which makes running at the correct speed and feed rate crucial. Running at an incorrect speed and feed rate can cause deflection, which will lead to an inaccurate engraving, chipping, breaking, or a poor surface finish.
At Harvey, we recommend a minimum spindle speed of 6,000 RPM. Operating at higher RPMs, when possible, offers even better support for tool tip integrity.
Higher speeds ensure tool stability as it will be less likely to cause vibration and reduces heat buildup during operation. Running too slowly generates excess heat and vibration leading to chipping, breakage, or having a poor surface finish. To help maintain tool tip integrity, it is important to follow the recommended depth of cut and consider the way the engraver enters the material.
Determining Depth of Cut
Many machinists are unaware that taking cuts deeper than 0.009 inches can shorten the lifespan of a Harvey engraving tool. For depth of cut ranging from 0.001 inch to 0.009 inches, you can operate within our stated speed and feed guidelines. If the operation requires a deeper groove, the chip load must be reduced accordingly. For depths between 0.010 inches and 0.015 inches, reduce the chip load by 20%. For depths ranging from 0.016 inches to 0.020 inches, reduce the chip load by 30%. Depth of cut also influences visibility. A deeper cut made with a tool that has a smaller angle can provide similar visibility to a shallower cut made with a tool that has a larger angle.
The image below illustrates different engraving depths using a 30° included angle. From left to right, the depths are 0.009 inches, 0.015 inches, and 0.020 inches. As depth increases, visibility improves. When engaging the tool with the workpiece, it is best to ramp into the material to protect the tool tip.
We recommend a ramp angle of 1° to 3° for ferrous materials such as stainless steel, and 3° to 10° for non-ferrous materials like aluminum or copper. If ramping is not an option, you may plunge the tool into the material. However, the chip load must be reduced by 50% during entry. Once the desired depth is reached, you can return to the recommended running parameters. Another key consideration is ensuring the workpiece is securely held in place.
Workholding Considerations
Runout or vibration during engraving can result in uneven cuts and tool failure. To prevent this, ensure that engraving tools are held in a sturdy toolholder and that the workpiece is secured. A shrink-fit toolholder minimizes runout and provides excellent stability. While ER collets are acceptable, they wear overtime. To verify an ER collet’s suitability, place an indicator on the tool shank and rotate the tool within the collet. The goal is to achieve the least possible runout, ideally no more than 0.0003 inches.
The workpiece should also be properly secured, either in a vise or a fixture. To detect vibrations during operation, listen for irregular noise or feel for vibrations through the CNC machine door. For cooling, coolants are recommended for metallic workpieces, while an air blast is preferable for non-metallic materials such as plastic.
When selecting an engraving tool, it is essential to choose the correct geometry for the operation, as well as the appropriate coating for the material being machined. Regardless of tip geometry, the engraving tool’s tip is its most fragile part. Proper speed, feed rate, and depth of cut are crucial for maximizing tool life.
For metallic workpieces, a cooling method such as coolant is necessary, while non-metallic workpieces require an air blast. Before starting a new engraving operation, double-check tool runout and ensure that the workpiece is securely held in place.
By following these best practices, CNC engraving operations can achieve high precision, longevity, and optimal tool performance.
Are You Ready to Put Your Engraving Knowledge to Use?
Browse Harvey Tool’s full selection of precision engravers, coatings, and geometries designed for optimal performance in a wide range of materials.
July 15, 2025/0 Comments/in Large Featured, Milling, Specialty Tools, Tool Selection/by Harvey Performance Company
Mold, Tool, and Die manufacturing demands a high level of precision. Whether you’re machining hardened tool steels, creating detailed mold cavities, or producing dies with complex geometries, the tooling used plays a critical role in ensuring consistent, repeatable results. To explore the full selection of tools relevant to this industry, including application-specific geometries and coatings, visit Harvey Tool’s Mold, Tool & Die Featured Solutions page.
Harvey Tool offers a comprehensive range of tools specifically engineered to meet the unique challenges of the Mold, Tool & Die industry. From tools designed to reach deep cavities to those that maintain surface finish in demanding materials, this offering is built to support precision and reliability throughout the machining process.
Tools included in this lineup are:
  • CVD Diamond End Mills– This Harvey Tool lineup of Diamond Tooling for Non-Ferrous Materials features true crystalline CVD diamond on a solid carbide substrate, making it ideal for machining graphite, composites, green carbide, and green ceramics.
  • End Mills for Hardened Steels– Engineered for hardened steels from 46Rc to 68Rc, this tool includes the latest generation AlTiN Nano coating for enhanced hardness and thermal resistance.
  • End Mills for Aluminum Alloys– We know a part is only as successful as its finish. That’s why our aluminum finishing solutions are crafted for mirror-like surface quality.
  • End Mills for Medium Alloy Steels– Engineered for versatility, these CNC-ground, AlTiN-coated tools excel in machining stainless, tool, and medium alloy steels.
  • Miniature Tapered End Mills– Tackling deep part features? Harvey Tool’s tapered Miniature End Mills offer unique geometries that take the challenge out of tough-to-reach cuts.
Diamond End Mills for Abrasive and Non-Ferrous Materials
Diamond tooling is essential to many moldmaking processes, particularly during electrode production and when machining non-metallic materials. Harvey Tool’s offering includes a wide selection of Diamond End Mills designed for use in abrasive and non-ferrous materials such as graphite, green carbide, green ceramics, and composites—materials commonly encountered in mold and die work.
These tools feature a CVD (Chemical Vapor Deposition) coating to promote longer tool life and uphold tight tolerances over extended machining cycles.
Highlighted tooling includes:
  • Finishers – Ball Profile (CVD Diamond)
    With available radii as small as 0.005″, these tools are ideal for finishing high-detail electrodes and intricate features.
  • Finishers – Corner Radius (CVD Diamond)
    Designed for applications requiring edge strength and tight tolerances, available with corner radii from 0.005″ to 0.0625″.
  • Standard Ball and Square Profiles (CVD Diamond)
    Feature reduced neck geometries for improved clearance in deep cavity or long-reach work.
Diamond End Mills are frequently used in electrode machining for EDM (Electrical Discharge Machining), where precision in non-metallic workpieces directly influences final mold quality.
All tools in the Mold, Tool & Die offering are fully stocked and available to ship same day, helping to reduce lead times and keep your production on schedule.
To view the full offering, including tools with specialized geometries and coatings, visit the Mold, Tool & Die Solutions page.
https://www.harveyperformance.com/wp-content/uploads/2025/07/Mold-Tool-Die-Featued-Image.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2025-07-15 08:02:462025-11-10 10:42:08Supporting Precision in Mold, Tool & Die Applications
January 29, 2025/0 Comments/in CNC Machining, Helical Solutions, Machining 101, Machining Techniques, Milling, Specialty Tools, Tool Geometry, Tool Information Guides, Tool Selection/by Thomas Donahue
Helical Solutions offers a variety of Tapered End Mills designed to enhance performance and efficiency in tapered wall applications. In this blog post, we’ll dive into the geometry of tapered end mills and explore their common applications to understand when they could be utilized to optimize your CNC machining application.
Tapered End Mill Geometry
Tapered End Mills bring many advantages to machining compared to standard end mills, but what is a Tapered End Mill? A standard end mill will have the same cutting diameter throughout the whole length of cut, whereas a taper mills starts at the shank or neck at a larger diameter and tapers down at a specific angle.
The angle of the taper can vary, but Helical Solutions’ tools feature angles ranging from .05° to 5°, which allows for a broad spectrum of cutting operations. A tapered length of cut or tapered neck can also provide increased strength and rigidity, compared to that of a standard end mill. Having a tapered length of cut makes it easier to create flat tapered walls on 3-axis machines and leads to a better finish.
Tapered End Mill
Standard End Mill
Common Taper Mill Applications
Tapered End Mills are used in any machining process that requires an angled surface. These tools are engineered for light profiling and finishing applications in mold and die pockets and other tapered wall applications.
Mold & Die Applications
Mold and die applications are a mass production manufacturing method that consists of shaping different types of metals and other materials. Molds are used to shape metals, allowing them to become solid in the mold, while dies use a mechanical force to cut the material into the desired shape.
A couple examples of mold and die applications are plastic bottles, car body parts, electronic components, cutlery, coins, and metal stamping parts.
Mold Tool & Die Example
Tapered End Mills Profiles
Taper mills are great for profiling with the ball nose version, and for light finishing and creating required draft angles with the square version. Which style is right for you?
Ball Nose Taper Mills
Ball Nose Tapered End Mills are great for profiling because the full radius at the bottom eliminates sharp edges, which leads to a smoother process.
Square Profile Tooling
The square version of the tapered end mill has a higher flute count and helix angle with a sharp cutting edge. This is better for light finishes on the walls of tools.
The draft angle determined in the design process is the amount of mold design can be tapered. A draft angle is a strategic angle or slope designed in the mold. The tapered angle in the tool allows for the draft angle to be formed easier compared to a straight shanked end mill. Having a draft angle in the mold allows for easier removal of the part so it does not get stuck to the mold.
Helical Solutions’ Tapered End Mills
Helical Solutions’ offering of Tapered End Mills feature a tapered profile design, variable pitch geometry for reduced harmonics and increased feed rates, and Aplus coating for increased performance in Cast Iron, Steel, and even Stainless Steel. These tools are offered in a 4 Flute Ball style, and a 5 Flute Square style, so you can select the end profile that best suits your specific toolpath.
Helical’s Tapered End Mills
4 Flute Ball (HTPR-4)
Helical’s 4 Flute Ball Tapered End Mills (HTPR-4) are fully stocked in 6 different angles per side (0.5°, 1°, 1.5°, 2°, 3°, 5°), and in 3 different cutter diameters (1/8”, 3/16”, ¼”). These tools feature a ball nose profile, allowing them to excel in a variety of different applications from 3D contouring and profiling to slotting. A Ball Nose End Mill has a full form radius, allowing machinists to utilize the entire radius when contouring and finishing a 3D surface.
5 Flute Square (HPTR-5)
Helical’s 5 Flute Square Tapered End Mills (HTPR-5) is also is also fully stocked 6 different angles per side (0.5°, 1°, 1.5°, 2°, 3°, 5°), and in 3 different cutter diameters (1/8”, 3/16”, ¼”). These tools feature a square profile for more precise finishing and the 5 flute design creates a larger core, allowing for better tool strength in roughing applications.
Taper Mill Tooling Wrapped-up
By understanding the unique features and advantages of this tooling, machinists can make informed decisions and achieve superior results in their projects. These feature unique geometry that enhances machining capabilities and ensures reliability and accuracy across a range of tapered wall applications.
https://www.harveyperformance.com/wp-content/uploads/2025/01/DSC_0434.jpg 525 1400 Thomas Donahue http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Thomas Donahue2025-01-29 15:55:382025-01-30 09:14:54A Closer Look at Helical Solutions’ Tapered End Mills
Save Time With Quick Change Tooling
April 10, 2020/2 Comments/in CNC Machining, Drilling & Holemaking, Micro 100, Specialty Tools, Tool Information Guides, Tool Selection, Turning/by Harvey Performance Company
Making a manual tool change on any CNC machine is never a timely or rewarding process. Typically, a tool change in a standard holder can take up to 5 minutes. Add that up a few times, and suddenly you have added significant minutes to your production time.
As CNC machine tool and cutting tool technology has advanced, there are more multi-functional tools available to help you avoid tool changes. However, sometimes it just isn’t feasible, and multiple tool changes are needed. Luckily, Micro 100 has developed a revolutionary new method to speed up tool changes significantly.
What is the Micro-Quik Tooling System?
Developed in Micro 100’s world-class grinding facility in Meridian, Idaho, the Micro 100 Micro-Quik tooling system is held to the same standards and tight tolerances as all of the Micro 100 carbide tooling.
The quick change tooling system allows for highly repeatable tool changes that save countless hours without sacrificing performance. This system combines a unique tool holder with a unique tool design to deliver highly repeatable and accurate results.
Each quick change tool holder features a locating/locking set screw to secure the tool and a locating pin which helps align the tool for repeatability. Removing a tool is as simple as loosening the set screw and inserting its replacement.
depiction of removing tool from quick change system
During tool changes, the precision ground bevel on the rear of the tool aligns with a locating pin inside the tool holder. The distance from this locational point to the tip of the tool is highly controlled under tight tolerances, meaning that the Micro-Quik tooling system ensures a very high degree of tool length and centerline repeatability. The “L4” dimension on all of our quick change tools, as seen in the image above, remains consistent across the entire product line. Check out the video below for a demonstration of the Micro 100 Micro-Quik system in action!
Quick Change Tooling Benefits
quick change system with micro 100 boring bar close up image
The most obvious benefit to using Micro 100’s Micro-Quik Quick Change Tooling System is the time savings that come with easier tool changes. By using the quick change holders in combination with quick change tooling, it is easy to reduce tool changes from 5 minutes to under 30 seconds, resulting in a 90% decrease in time spent swapping out tools. This is a significant benefit to the system, but there are benefits once the tool is in the machine as well.
As mentioned above, the distance from the locational point on each tool shank to the tip of the tool is highly controlled, meaning that regardless of which type of tool you insert into the holder, your stick out will remain the same. This allows you to have confidence in the tooling and does not require additional touch offs, which is another major time saver.
assortment of boring bars with quick change system
By removing additional touch-offs and tool changes from your workflow, you also reduce the chances for human or machine error. Improper touch-offs or tool change errors can cause costly machine crashes and result in serious repairs and downtime. With the Micro 100 Micro-Quik Quick Change Tooling System, initial setups become much easier, allowing you to hit the cycle start button with total confidence for each run.
By making a few simple changes to your tool holding configurations and adopting the Micro-Quik system, your shop can save thousands in time saved, with less machine downtime and increased part production. To learn more about the Micro 100 Micro-Quik cutting tools and tool holders, please visit Micro 100.
https://www.harveyperformance.com/wp-content/uploads/2020/04/Feature-Image-Quick-Change-Tooling-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2020-04-10 08:00:002023-10-05 08:58:22Save Time With Quick Change Tooling
November 22, 2019/1 Comment/in CNC Machining, Harvey Tool, Milling, Specialty Tools, Tool Geometry, Tool Information Guides, Tool Selection/by Harvey Performance Company
Harvey Tool Chamfer Cutters
https://www.harveyperformance.com/wp-content/uploads/2017/08/Feature-Image-Uses-of-Chamfer-Mill-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2019-11-22 08:20:372024-02-12 13:58:50Selecting the Right Chamfer Cutter Tip Geometry
May 6, 2019/0 Comments/in CNC Machining, CNC Programming, Machining Techniques, Specialty Tools, Tech Tips/by Harvey Performance Company
What is a Drop-Hole?
graphic showing holes with and without drop hole allowance
5 unique machining operations with drop hole allowance
When Not to Drop Hole
machining operations without drop hole allowance
Drop-Hole Placement
proper placement of hole when using drop hole allowance
graphic showing the use of a drop hole for o-ring seals between high and low pressure areas
https://www.harveyperformance.com/wp-content/uploads/2019/05/Feature-Image-Drop-Hole-Allowance-IMG-1.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2019-05-06 09:48:552023-10-24 10:53:22When to and Not to Use Drop Hole Allowance
November 16, 2018/13 Comments/in Harvey Tool, Machining Techniques, Specialty Tools, Tool Geometry, Tool Information Guides/by Harvey Performance Company
Understanding the Distinctions
harvey tool marking cutters ad
harvey tool doubled ended engraving cutter
Harvey Tool Product Offering
types of cnc engraver tips, pointed, radiused, and tipped-off
Choosing the Right Tool
https://www.harveyperformance.com/wp-content/uploads/2018/11/Feature-Image-Engravers-Marking-Cutters-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-11-16 08:57:532024-04-12 11:55:11Main Differences Between Engravers & Marking Cutters
June 8, 2018/3 Comments/in Harvey Tool, Specialty Tools, Tool Information Guides, Tool Selection/by Harvey Performance Company
Corner Rounding End Mill with dimension callouts
2 flute and 4 flute corner rounding end mills with 5° flares
Front or Back
harvey tool back Corner Rounding End Mill
These tools are often offered in 2, 3, and 4 flute styles.  2 flute styles are normally used for aluminum and non-ferrous materials, although 3 flutes is quickly becoming a more popular choice for these materials, as they are softer than steels so a larger chip can be taken without an impact on tool life. 4 flutes should be chosen when machining steels to extend tool life by spreading out the wear over multiple teeth. 4 flute versions can also be run at higher feeds compared to 2 or 3 flute tools.
https://www.harveyperformance.com/wp-content/uploads/2018/06/Feature-Image-Corner-Rounded-EMs-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-06-08 10:00:442024-02-12 11:35:004 Essential Corner Rounding End Mill Decisions
March 13, 2018/14 Comments/in CNC Machining, Machining 101, Machining Techniques, Quick Tips, Specialty Tools, Titan USA, Tool Selection/by Harvey Performance Company
High Precision Tools
red hand deburring tool
examples of cnc undercutters and chamfer mills
machinist hand deburring with a motorized hand tool
https://www.harveyperformance.com/wp-content/uploads/2018/03/Feature-Image-Stop-Deburring-by-Hand-IMG-1.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-03-13 16:26:182024-02-12 14:37:41Why You Should Stop Deburring by Hand
Undercutting End Mills for Maximum Versatility
August 16, 2017/0 Comments/in Harvey Tool, Machining Techniques, Specialty Tools, Tool Information Guides, Tool Selection, Tools In Action/by Harvey Performance Company
Undercutting end mills, also known as lollipop cutters or spherical ball end mills, are a common choice for machining undercuts. An undercut is a common part feature characterized by one part of a workpiece “hanging” over another. Undercuts are typically difficult, or even impossible, to machine with a standard tool, especially on 3-axis machines. In many cases, a specialty tool is needed to tackle this feature. Although they are frequently associated with a singular use, undercutters are actually very versatile tools that are worth keeping on hand for a variety of operations.
Undercutting
undercutting end mill ideal operations in machining
Unsurprisingly, these tools are very well suited to undercutting operations. Creating an undercut on a part can be tricky and time consuming, especially when forced to rotate the workpiece. Fortunately, this can be greatly simplified with an undercutter.
Exactly what tool to use depends on the geometry of the feature and the part. These tools are available with a range of wrap angles like 220°, 270°, and 300°. Greater wrap angles are the result of a thinner neck and create a more spherical cutting end. This style offers more clearance at the cost of rigidity. Likewise, undercutting end mills with lower wrap angles sacrifice clearance for greater rigidity.
Deburring & Edgebreaking
deburring with undercutting end mills
Since undercuts have a wrap angle that is greater than 180°, they are very well-suited to deburring or edgebreaking anywhere on your workpiece, including the underside. Deburring your parts by hand can be inefficient for your shop – using an undercutting end mill instead will save you time and money. Edgebreaking operations are often a critical final step to create a part that looks and feels like a finished product and that is safe to handle.
All undercutting end mills can be used to deburr and edgebreak, which makes them a useful tool to have on hand in any shop. Some manufacturers also offer specialized deburring tools that are designed with a right and left hand flute orientation, giving them “teeth” that make them particularly useful for deburring complex shapes. Using a deburring tool in a 5-axis machine often makes it possible to deburr or edgebreak an entire workpiece in one shot.
slotting uses of undercutting end mill
Most machinists might not think of undercutting end mills for slotting, but they are fully capable of this operation. An equivalent slot can be machined with a regular ball end mill, but doing so might not be feasible due to clearance issues – an undercutter has a reduced neck, unlike a standard ball end mill. Additionally, using an undercutter to slot can save time switching to an equivalent ball end mill.
Harvey Tool Stocks a Wide Variety of Undercutting End Mills Perfect for Your Next Machining Job
Since only 180° of the cutting end can be used to slot, undercutting end mills with lower wrap angles and thicker necks are best suited to slotting. However, high helix undercutting tools may be ideal if improved finish and increased chip removal are important to the operation.
Contouring & Profiling
contouring and profiling illustration with lollipop end mill
With their wrap angle and increased clearance, undercutting end mills are very useful for both simple and complicated contouring and profiling operations. Their versatility means that it is sometimes possible to accomplish the entire operation with a single tool, rather than several, especially when 5-axis milling.
Reduced shank tools offer the most versatility in complex contouring and profiling operations. The ability to chuck these tools at any depth means that they are capable of maximum clearance.
Choosing An Undercutting End Mill
While most undercutting end mills are conceptually similar, there are a few key differences that must be considered when picking the right tool for your job. Harvey Tool offers the following styles as stock standard tools.
selection undercutting end mills sizes and styles
https://www.harveyperformance.com/wp-content/uploads/2017/08/Feature-Image-Undercutting-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-08-16 16:00:002025-11-12 15:58:23Undercutting End Mills for Maximum Versatility
Page 1 of 212
