Harvey Tool stocks several different types of miniature drills, but which option is right for you, and how does each drill differ in geometry and overall tool coating?
For many operations, drilling the actual hole is only the beginning of the job. Some parts may require an ultra-tight tolerance, for which a Miniature Reamer (tolerances of +.0000″/-.0002″ for uncoated and +.0002″/-.0000″ for AlTiN Coated) can be used to bring a hole to size.
