In the loupe
corehog logo
CoreHog is the premier manufacturer of composite cutting tools. A leader in innovation, CoreHog engineers advanced tooling for composites, a rapidly-evolving, modern material group. In this section of “In the Loupe,” find technical help posts related to the machining of, and the tooling for, composite materials.
List List Menu
  • Home
  • How-To’s
  • Technical Tips
  • Tools In Action
  • Featured Customers
  • Tool Guides
  • In the Loupe TV
New From CoreHog
July 8, 2024/by Sarah Wasson
Traditional vs Free Cutting Honeycomb Core Tools
May 16, 2024/by Harvey Performance Company
cnc machine
CFRP: Running Parameters, Tool Life, and Safety Tips
December 7, 2022/0 Comments/in Composites, Milling/by Matthew Hernandez
Carbon Fiber Reinforced Polymers (CFRP) is a collection of carbon fibers that, when bound together via resin, creates a material with a wide range of application possibilities. It’s strong, durable, and resistant to corrosion, making it an advantageous material for use in several advanced industries, including the aerospace and automotive industries. Despite its unique abilities, […]
Read more
https://www.harveyperformance.com/wp-content/uploads/2022/12/Feature-Image-CFRP-Part2.jpg 525 1400 Matthew Hernandez http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Matthew Hernandez2022-12-07 08:39:552025-11-20 09:24:21CFRP: Running Parameters, Tool Life, and Safety Tips
selection of end mills on a carbon fiber sheet
CFRP: Material Properties and Tool Selection
October 27, 2022/0 Comments/in Composites, Large Featured/by Matthew Hernandez
Carbon Fiber Reinforced Polymers (CFRP) is composed of carbon fibers, bound with resin, to create a groundbreaking material that has proven to have limitless application possibilities in a wide range of composite cutting industries. Due to its attractive properties of strength, durability, corrosion resistance, and its lightweight nature, there has been a rising utilization of […]
Read more
https://www.harveyperformance.com/wp-content/uploads/2022/10/Feature-Image-Machining-Carbon-Fiber-1.jpg 600 1599 Matthew Hernandez http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Matthew Hernandez2022-10-27 09:43:302025-11-20 09:23:34CFRP: Material Properties and Tool Selection
Coreslicer chart
Benefits of CoreHog Assembly Style Tools in Composites
October 6, 2022/0 Comments/in CNC Machining, Composites, Small Featured/by Harvey Performance Company
Harvey Performance Company brand CoreHog, which focuses on the manufacturing of the world’s most advanced composite and honeycomb core cutting tools, fully stocks an array of “Assembly Style Cutting Tools,” which allow a machinist to build the perfect solution for their specific application’s needs. In doing so, a cutting tool can be optimized for specific […]
Read more
https://www.harveyperformance.com/wp-content/uploads/2022/10/Corehogassemblytools.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-10-06 14:58:342025-11-20 09:49:14Benefits of CoreHog Assembly Style Tools in Composites
composite material cutting tools
May 21, 2018/0 Comments/in CNC Machining, Composites, Material Specific, Tool Selection/by Harvey Performance Company
Composite Materials A material is classified as a composite if it is made up of at least two unique constituents that when combined yield beneficial physical and mechanical properties for a number of different applications. A binding agent that is the matrix material is filled with either particles or fibers of a second material that […]
Read more
https://www.harveyperformance.com/wp-content/uploads/2018/05/Feature-Image-Machining-Composites-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-05-21 15:10:122025-09-08 11:13:01Ideal Tooling for Machining Composites
compression cutters
Avoid Composite Delamination With Compression Cutters
September 12, 2017/0 Comments/in CNC Machining, Composites, How-To's, Machining Techniques, Tool Selection, Troubleshooting Tips/by Harvey Performance Company
Composites are a group of materials made up of at least two unique constituents that, when combined, produce mechanical and physical properties favorable for a wide array of applications. These materials usually contain a binding ingredient, known as a matrix, filled with particles or fibers called reinforcements. Composites have become increasingly popular in the Aerospace, […]
Read more
https://www.harveyperformance.com/wp-content/uploads/2017/09/Feature-Image-Compression-Cutters-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-09-12 16:00:532025-11-12 16:00:14Avoid Composite Delamination With Compression Cutters
five cnc composte holemaking tools
April 21, 2017/0 Comments/in CNC Machining, Composites, Drilling & Holemaking, Holemaking, Machining Techniques, Material Specific, Milling, Tool Selection/by Harvey Performance Company
Harvey Tool’s Miniature High Performance Composite Drills are specifically designed with point geometry optimized for the unique properties of composite materials. Our Double Angle style is engineered to overcome common problems in layered composites and our Brad Point style is built to avoid the issues frequently experienced in fibrous composites.
Read more
https://www.harveyperformance.com/wp-content/uploads/2017/04/Feature-Image-Composite-Holemaking-Challenges.jpg 525 1401 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-04-21 10:00:312024-11-06 13:16:28Overcoming Composite Holemaking Challenges
The Latest from In The Loupe
  • Manufacturing Day Swag Box Giveaway
  • IMTS Limited Edition Giveaway
  • ITL TV: Stop the Chatter: How End Mill Geometry Reduces Vibration
Stay In The Loupe
