multi functional cutting tools
March 23, 2018/2 Comments/in CNC Machining, Harvey Tool, Machining 101, Machining Techniques, Milling, Tool Geometry, Tool Selection/by Harvey Performance Company
Drill/End Mills
harvey tool combination drill end mill
infographic showcasing 5 unique drill mill operations
Undercutting End Mills
harvey tool undercutting lollipop end mill
infographic of four unique uses for undercutting end mills
Double Angle Shank Cutters
harvey tool double angle shank cutter
infographic showing 6 different uses of double angle shank cutters
Flat Bottom Tools
two stacked harvey tool cnc tools, top being a flat bottom drill and bottom a flat bottom counterbore
infographic showing 5 uses of flat bottom cnc tools. thin plate, cross hole, irregular surface, angled, and half hole drilling
infographic showing the five unique uses for flat bottom counterbores
Adjustable Chamfer Cutters
harvey tool adjustable chamfer mill set to 45 degrees
adjustable chamfer cutter inserts and hardware
https://www.harveyperformance.com/wp-content/uploads/2018/03/Feature-Image-Multi-functional-Tools-IMG.png 527 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-03-23 09:34:452025-09-08 11:16:19Multi-Functional Tools Every Shop Should Have
End Mill Manufacturing Helical Solutions: Behind the Scenes
Undercutting End Mills for Maximum Versatility
BrickTactical Brick Tactical – Featured Customer
end mill for titanium Helical HVTI Cutter: High Efficiency Milling Titanium
  1. Taylor Bishop
    Taylor Bishop says:
    May 3, 2018 at 11:41 am
    Thanks for helping me learn more about multi-functional tools. It’s good to know that for the adjustable chamfer cutters you can just adjust the carbide inserts to mill at different angles. If this is the case, it’s probably important to make sure these inserts stay in good condition, especially if you use the tool for various projects.
  2. louis sham
    louis sham says:
    May 23, 2021 at 10:38 am
    Carrying your toolbox wherever you go is bound to get tiring. Having a multi-function tool enables you to never worry about that again. You can tackle unexpected tasks with just one tool, which will save you space and money.
