Tag Archive for: cross hole drilling
April 19, 2018/0 Comments/in Drilling, Drilling & Holemaking, Harvey Tool, Holemaking, Tool Geometry, Tool Information Guides, Tool Selection/by Harvey Performance Company
Harvey Tool stocks several different types of miniature drills, but which option is right for you, and how does each drill differ in geometry and overall tool coating?
https://www.harveyperformance.com/wp-content/uploads/2018/04/Featured-Image-Miniature-Drill-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-04-19 08:00:482024-11-07 16:28:32Selecting the Right Harvey Tool Miniature Drill
January 23, 2018/13 Comments/in Drilling, Drilling & Holemaking, Harvey Tool, Holemaking, Machining 101, Tool Geometry, Tool Information Guides, Tool Selection/by Harvey Performance Company
Flat Bottom Drills
Flat Bottom Drill
infographic showing 5 different Flat Bottom Drill Operations
Thin Plate Drilling
Crosshole Drilling
Angled Drilling
Half Hole Drilling
infographic showcasing 5 different uses of flat bottom counterbores
Bore & Finish Drilled Holes
Straighten Misaligned Holes
Remove Drill Points
Remove End Mill Dish
https://www.harveyperformance.com/wp-content/uploads/2018/01/Feature-Image-10-Reasons-Flat-Bottom-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-01-23 09:54:442024-02-12 14:17:1810 Reasons to Use Flat Bottom Tools
