Tag Archive for: flat bottom drills
April 19, 2018/0 Comments/in Drilling, Drilling & Holemaking, Harvey Tool, Holemaking, Tool Geometry, Tool Information Guides, Tool Selection/by Harvey Performance Company
Harvey Tool stocks several different types of miniature drills, but which option is right for you, and how does each drill differ in geometry and overall tool coating?
https://www.harveyperformance.com/wp-content/uploads/2018/04/Featured-Image-Miniature-Drill-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-04-19 08:00:482024-11-07 16:28:32Selecting the Right Harvey Tool Miniature Drill
April 19, 2018/1 Comment/in CNC Machining, Holemaking, How-To's, Machining 101/by Harvey Performance Company
What are Pecking Cycles?
aluminum pecking cycles
hardened steels chart
prehardened steels chart
https://www.harveyperformance.com/wp-content/uploads/2018/04/Featured-Image-Pecking-Cycle-IMG-1.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-04-19 07:44:542022-01-17 10:16:34Choosing the Right Pecking Cycle Approach
March 23, 2018/2 Comments/in CNC Machining, Harvey Tool, Machining 101, Machining Techniques, Milling, Tool Geometry, Tool Selection/by Harvey Performance Company
Drill/End Mills
harvey tool combination drill end mill
infographic showcasing 5 unique drill mill operations
Undercutting End Mills
harvey tool undercutting lollipop end mill
infographic of four unique uses for undercutting end mills
Double Angle Shank Cutters
harvey tool double angle shank cutter
infographic showing 6 different uses of double angle shank cutters
Flat Bottom Tools
two stacked harvey tool cnc tools, top being a flat bottom drill and bottom a flat bottom counterbore
infographic showing 5 uses of flat bottom cnc tools. thin plate, cross hole, irregular surface, angled, and half hole drilling
infographic showing the five unique uses for flat bottom counterbores
Adjustable Chamfer Cutters
harvey tool adjustable chamfer mill set to 45 degrees
adjustable chamfer cutter inserts and hardware
https://www.harveyperformance.com/wp-content/uploads/2018/03/Feature-Image-Multi-functional-Tools-IMG.png 527 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-03-23 09:34:452025-09-08 11:16:19Multi-Functional Tools Every Shop Should Have
January 23, 2018/13 Comments/in Drilling, Drilling & Holemaking, Harvey Tool, Holemaking, Machining 101, Tool Geometry, Tool Information Guides, Tool Selection/by Harvey Performance Company
Flat Bottom Drills
Flat Bottom Drill
infographic showing 5 different Flat Bottom Drill Operations
Thin Plate Drilling
Crosshole Drilling
Angled Drilling
Half Hole Drilling
infographic showcasing 5 different uses of flat bottom counterbores
Bore & Finish Drilled Holes
Straighten Misaligned Holes
Remove Drill Points
Remove End Mill Dish
https://www.harveyperformance.com/wp-content/uploads/2018/01/Feature-Image-10-Reasons-Flat-Bottom-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-01-23 09:54:442024-02-12 14:17:1810 Reasons to Use Flat Bottom Tools
