Tag Archive for: Chip Evacuation
  • Increased tool life.
single flute end mill for pastics
While many manufacturers will specially coat a standard end mill at your request, this takes added time and cost. In its Material Specific catalog sections, Harvey Tool offers coated tools stocked and ready to ship. For instance, their Hardened Steels and Exotic Alloys categories utilize AlTiN Nano coating. This is a unique nanocomposite coating that has a max working temperature of 2,100° F and shows improved performance in materials such as Hardened Steels, Titantium Alloys, and Inconel, among others.
Miniature End Mill
Part Number: 836408
Material: 6061 Aluminum
Application: Slotting
Speed: 10,000 RPM
Chip Load: .00124 IPT
Linear Feed: 37.2 IPM
DOC: .04375
harvey tool miniature end mill
Part Number: 942308
Speed: 10,000 RPM
Chip Load: .00165 IPT
Linear Feed: 49.5 IPM
DOC: .0625
harvey tool miniature variable helix end mill
Extensive Cost Savings
material specific tooling benefit chart in cost savings
Confidently Select Your Next Thread Mill
Thread Mill Product Offering
Single Form
single form harvey tool thread mill
  1. Ground Flat – Instead of a sharp point these tools have a ground flat to help ensure long tool life.
  2. Eccentric Relief – Gives the cutting edges extra strength for the high feeds at relatively low RPMs required for harder materials.
  3. AlTiN Nano Coating – Allows for superior heat resistance.
single form thread mill for hardened steels
Tri-Form
tri form thread mill from harvey tool
Multi-Form
coolant through multi form thread mill
Long Flute
long flute harvey tool thread mill
N.P.T. Multi-Form
npt thread mill from harvey tool
heat generation in standard versus hem milling and their associated depths of cut
Chip Thinning Awareness
infographic showcasing chip thinning in relation to step over
Consider Climb Milling
infographic showing climb versus conventional milling in feed path and end mill direction
  • Traditional Roughing
  • Slotting
  • Finishing
  • Contouring
  • Plunging
  • High Efficiency Milling
Material:
Application:
graphic showcasing the tool face of end mills from 2 to 12 flutes
Length of Cut & Reach
Tool Profile
end mill graphic with dimension callouts
  • Prolonged Tool life
  • Improved Chip Evacuation
multiple end mills after being coated, zoomed in on cutting faces
face of a staggered tooth keyseat cutter
Three Key Benefits
Indexing
Increased Feed Rates
Better Part Finish
staggered tooth keyseat cutter working in a cnc machine
Opt for a Smoother Operation
B&R Custom machining
aerospace machining
B&R custom machining
infographic showcasing all aspects axii for high balance machining
cnc high balance end mills in both 2 and 3 flute designs
Utilizing Tap Testers
What Tap Testers Do
How Tap Testing Works
how to properly tap test a cnc tool
helical solutions ball end mill for stainless steels
HEV-5
bag of copper chips from cnc machining
Coolant
Tool Engagement
infographic showcasing the rotation and movement of a cutting tool in climb milling
Initial Workpiece Engagement
Gummy Materials Summarized
What is a Tight Tolerance?
harvey tool sample table heading showing tool tolerances in D1 and L2 callouts
How Are Tolerances Used?
tooling tolerances of an end mill in dia and LOC
Spotting Drills
spotting drill with dimension callouts
Reamers
miniature reamers with dimension callouts
Be Wary of Deflection
Maintaining tolerances when machining walls is made difficult by tool deflection, or the curvature a tool experiences when a force is applied to it. Where an angle is appearing on a wall due to deflection, opt for a reached tool to allow for less deflection along the tool’s neck. Further, take more axial depths of cut and machine in steps with finishing passes to exert less pressure on the tool. For surface finish tolerances, a long fluted tool may be required to minimize evidence of a tool path left on a part.infographic showcasing cutting forces and tool deflection in machining
Tolerances Summarized
