Tag Archive for: Chip Evacuation
diamond tool coatings
Amorphous Diamond Coating
amorphous diamond coating
CVD Diamond Coating
Polycrystalline Diamond (PCD)
Coating Hardness & Thickness
Flute Styles
PCD Diamond end mill
PCD Ball End Mill
CVD Diamond end mill
CVD Ball End Mill
Proper Uses
Cut to the Point
Deflection Can Result In:
  • Subpar surface finish
Tool Deflection Remedies
Minimize Overhang
extended reach tool
Image Source: @NuevaPrecision
Long Flute vs. Long Reach
tool deflection
tool deflection graph
long reach end mill
Long Reach Tool: Variable Helix End Mills for Exotic Alloys – Ball – Long Reach, Stub Flute
long flute tool
core diameter vs neck diameter
Deflection Summarized
Tool Geometry
flute count for aluminum
Helix Angles
Aluminum Machining end mill helix choices
Tooling Options
Chipbreaker Tooling
Chipbreaker Aluminum
High Balance End Mills
What are Pecking Cycles?
aluminum pecking cycles
hardened steels chart
prehardened steels chart
Recent  Advances
Increased Time Savings
Reduced Cycle Times
Improved Consistency
CNC Contouring planes
CNC Contouring ball end mill
tool wear Shop Inefficient
Subpar Part Finish
Inefficient Coolant Usage
chamfer mills
multiaxis machining
Shut Up Tool Chatter With Harvey Tool’s Material Specific Tooling
helical reduced neck tool
Ensure a Secure Connection
