Tag Archive for: Chip Evacuation
Work Hardening and When it Should Scare You
Soften Up Work Hardening With Harvey Tool’s Speeds and Feeds
Work Hardening Overview
titanium packed ball bearing
Major Problems
work hardening
How To Avoid Work Hardening
metal chips in cnc mill form chipbreaking
Helical Part No.33737
Material4340 Steel
ADOC2.545″
RDOC.125″
Speed2,800 RPM
Feed78 IPM
Why Flute Count Matters
Click Here to Get Started.
Tool Geometry Basics
flute count core
Material Considerations
end mill flute count
flute count
How to Avoid Composite Delamination With Compression Cutters
Using Compression Cutter End Mills in Composite Materials
compression cutters
Benefits of HEM:
  • Faster cycle times.
  • Overall cost savings
small harvey tool end mill for micromachining
micromachining
Titanium Varieties
Titanium 6AL4V
Titanium Concerns
Workholding
Heat Generation
cutting tools for titanium
Galling and Built-Up Edge
Titanium Solutions
Tooling Solutions
machining titanium
Pre-Drilled Hole
tool entry predrill
Helical Interpolation
helical interpolation
Ramping-In
ramping
Hard/Ferrous Materials: 1°-3°
arching with end mill
Straight Plunge
tool entry
Straight Tool Entry
tool entry
Roll-In Tool Entry
tool entry
Cutting With Dovetails
Check our Harvey Tool’s Comprehensive Selection of Dovetail Cutters that Ship to You Today.
Avoiding Tool Failure
dovetail cutters
nondrop-hole dovetail cutters
dovetail cutters with different neck diameters
microdovetailing with dovetail cutter
5. Failing to Climb Mill.
6. Improper Chip Flushing.
7. Giving the Job Away.
Selecting the Right Plastic Cutting End Mill
Choose Workholding Method
plastic cutter selection
Determine Heat Tolerance
The amount of heat generated should always be considered prior to any machining processes, but this is especially the case while working in plastics. While machining plastics, heat must be removed from the contact area between the tool and the workpiece quickly and efficiently to avoid melting and chip welding.
For plastics with a higher heat tolerance, a Two or Three Flute Plastic Cutting End Mill can be utilized. Because it has more cutting edges and allows for higher removal rates, its tool life is extended.
The polymer arrangement in plastics can cause many burrs if the proper tool is not selected. Parts that require hand-deburring offline after the machining process can drain shop resources. A sharp cutting edge is needed to ensure that the plastic is sheared cleanly, reducing the occurrence of burrs. Three Flute Plastic Cutting End Mills can reduce or eliminate the need to hand-deburr a part. These tools employ an improved cutting action and rigidity due to the higher flute count. Their specialized end geometry reduces the circular end marks that are left behind from traditional metal cutting end mills, leaving a cleaner finish with minimal burrs.
Shop Harvey Tool Plastic Cutting End Mills Today
Flute Count Case Study
3 FLUTE PLASTIC FINISHER: A facing operation was performed on a separate acrylic piece with a specialized 3 Flute Plastic Finisher End Mill. The specialized cutting end left minimal swirling marks and resulted in a smoother finish.
Avoid Tool Deflection
tool deflection
progressive step drilling
Achieve Optimal Finish
Deep Cavity Milling
Mill to the Required Depth
Confidently Machine Deeper With Harvey Tool’s Extended Reach Tool Holders
Evacuate Chips Effectively
that must be avoided.
Deep Cavity Milling
