What are Pecking Cycles?
aluminum pecking cycles
hardened steels chart
prehardened steels chart
Recent  Advances
Increased Time Savings
Reduced Cycle Times
Improved Consistency
CNC Contouring planes in multiaxis machining including, x, y and z axii
cnc contouring undercutting ball end mill
Drill/End Mills
harvey tool combination drill end mill
infographic showcasing 5 unique drill mill operations
harvey tool undercutting lollipop end mill
infographic of four unique uses for undercutting end mills
Double Angle Shank Cutters
harvey tool double angle shank cutter
infographic showing 6 different uses of double angle shank cutters
Flat Bottom Tools
two stacked harvey tool cnc tools, top being a flat bottom drill and bottom a flat bottom counterbore
infographic showing 5 uses of flat bottom cnc tools. thin plate, cross hole, irregular surface, angled, and half hole drilling
infographic showing the five unique uses for flat bottom counterbores
Adjustable Chamfer Cutters
harvey tool adjustable chamfer mill set to 45 degrees
adjustable chamfer cutter inserts and hardware
High Precision Tools
red hand deburring tool
examples of cnc undercutters and chamfer mills
machinist hand deburring with a motorized hand tool
Milling Machines vs. Lathe Machines
Most modern manufacturing centers have both milling machines and lathe machines. Each machine follows the same machining principle, known as subtractive machining, where you begin with a block of material and then shape that material into the desired specifications. How the part is actually shaped is the key difference between the two machines. Understanding the differences in more depth will help in putting the right part in the right machine to maximize their capabilities.
white and blue cnc lathe
An Example of a Lathe Machine
cnc milling machine
An Example of a Milling Machine
Operation
The major difference between a milling machine and a lathe machine is the relationship of the workpiece and the tool.
Lathe Machines
In a lathe, the workpiece that is being machined spins about it’s axis, while the cutting tool does not. This is referred to as “turning”, and is effective for creating cylindrical parts. Common operations done on a lathe include drilling, boring, threading, ID and OD grooving, and parting. When looking to create quick, repeatable, and symmetrical cylindrical parts, the lathe machine is the best choice.
adjustable boring bar turning a part in a cnc lathe
Milling Machines
The opposite is true for milling machines. The tool in a milling machine rotates about its axis, while the workpiece does not. This allows the tool to approach the workpiece in many different orientations that more intricate and complex parts demand. If you can program it, you can make it in a milling machine as long as you have the proper clearance and choose the proper tooling.
cnc multi axis machine machining a turbine part
Best Practice
The best reason to use a milling machine for an upcoming project is the versatility. The tooling options for a milling machine are endless, with hundreds of available specialty cutting tools and various styles of end mills which make sure you are covered from start to finish on each job. A mill can also cut more complex pieces than a lathe. For example, it would impossible to efficiently machine something like an intake manifold for an engine on a lathe. For intricate parts like that, a milling machine would be required for successful machining.
While lathe machines are more limited in use than a milling machine, they are superior for cylindrical parts. While a mill can make the same cuts that a lathe does, it may need multiple setups to create the same part. When continuous production of cylindrical parts is necessary, a lathe will outperform the mill and increase both performance and efficiency.
infographic showing x, y and z axii
Using Traditional Roughing
Using a Long Length of Cut
Flat Bottom Drills
Flat Bottom Drill
infographic showing 5 different Flat Bottom Drill Operations
Thin Plate Drilling
Crosshole Drilling
Angled Drilling
Half Hole Drilling
infographic showcasing 5 different uses of flat bottom counterbores
Bore & Finish Drilled Holes
Straighten Misaligned Holes
Remove Drill Points
Remove End Mill Dish
Material Removal Rate (MRR), otherwise known as Metal Removal Rate, is the measurement for how much material is removed from a part in a given period of time. Every shop aims to create more parts in a shorter period of time, or to maximize money made while also minimizing money spent. One of the first places these machinists turn is to MRR, which encompasses Radial Depth of Cut (RDOC), Axial Depth of Cut (ADOC), and Inches Per Minute (IPM) to create the MRR triangle where all three figures impact each other. If you’re aiming to boost your shop’s efficiency, increasing your MRR even minimally can result in big gains by decreasing cycle times and ultimately freeing up machines for increased productivity.
Click Here to Download the High Efficiency Milling (HEM) Guidebook
How to Calculate MRR In Machining
Material Removal Rate Formula
The Material Removal Rate equation is RDOC x ADOC x Feed Rate (IPM). As an example, if your RDOC is .500″, your ADOC is .100″ and your Feed Rate is 41.5 inches per minute, you’d calculate MRR the following way:
Infographic showcasing material removal rate equation
Optimizing Efficiency
The following MRR machining chart illustrates how a 1/2″, 5-flute tool will perform in Steel when varying ADOC and RDOC parameters are used. You can see that by varying the ADOC and RDOC, a higher feed rate is achievable, and thus, a higher MRR. In this case, pairing a high ADOC, low RDOC approach with an increased feed rate was most beneficial. This method has become known as High Efficiency Milling.
Axial Depth of CutRadial Depth of CutFeed RateMaterial Removal Rate
 .125″ .200″19.5 IPM .488 in.³/min.
.250″.150″26.2 IPM.983 in.³/min.
.500″.100″41.5 IPM2.08 in.³/min.
.750″.050″89.2 IPM3.35 in.³/min.
1.00″.025″193 IPM4.83 in.³/min.
High Efficiency Milling (HEM) is a milling technique for roughing that utilizes a lower RDOC and a higher ADOC strategy. This spreads wear evenly across the cutting edge, dissipates heat, and reduces the chance of tool failure. This results in a greater ability to increase your MRR in machining, while maintaining and even prolonging tool life versus traditional machining methods.
HEM VS Traditional Milling
The image referenced below compares the differences between traditional milling and the newer High Efficiency Milling technique in achieving adequate material removal. A traditional milling strategy requires the application of work and heat along a smaller portion of the cutting edge, while the HEM technique disperses heat more evenly across the entire cutting edge. This method calls for more radial passes which utilize a larger portion of the cutting edge, as opposed to axial passes that lead to a higher likelihood of tool failure over time.
infographic showcasing difference between traditional and hem depths of cut and heat generated
Obviously, with higher MRR’s, chip evacuation becomes vitally important as more chips are evacuated in a shorter period of time. Utilizing a tool best suited for the operation – in terms of quality and flute count – will help to alleviate the additional workload. For softer materials lower flute count tools will traditionally be the best choice. The thinner core allows for deeper flute valleys which aid in enhanced chip evacuation and ultimately increased MRR. On the other hand, harder materials require higher flute count tools with shallower flute valleys. This leads to less material removed per tooth, however tool life is substantially increased over the historic usage of lower flute count tools in these materials.
Additionally, a tool coating optimized for your workpiece material can significantly help with chip packing. First, tool coatings increase heat resistance of the tool allowing for faster cutting speeds leading to increased MRR. Secondly, coatings increase the lubricity of the cutting tool allowing for enhanced chip evacuation and lessened friction. This enhanced chip evacuation allows for the most efficient metal removal rate possible.
Further, compressed air or coolant can help to properly remove chips from the tool and workpiece. There are different three types of coolant delivery methods one could utilize in increasing metal removal rate.
Compressed Air
While having no lubricity purpose, the air coolant delivery method is made to cool and clear chips. This method does not cool as effectively as other coolant-based solutions, however it is preferred for more sensitive materials where thermal shock is a concern.
Flood
Flooding is a low pressure coolant delivery method which creates lubricity in order to evacuate chips from a part. This is necessary to prevent chip recutting which is likely to damage a cutting tool. This method of delivery is the most common choice for the widest range of machining operations.
High Pressure
This method is similar to flood coolant, however it is used to instantly cool a part and blast chips away with a high pressure of delivery. While highly effective at chip evacuation, this option is most likely to damage or break more fragile cutting tools. High pressure coolant delivery is most often utilized in deep pocket machining and drilling operations due to its increased ability to flush chips.
High efficiency milling guidebook ad
In conclusion, optimizing workplace efficiency is vital to sustained success and continued growth in every business. This is especially true in machine shops, as even a very minor adjustment in operating processes can result in a massive boost in company revenue. Proper machining methods will boost MRR, minimize cycle times, prolong tool life, and maximize shop efficiency.
